BaseCamp überträgt keine Tracks mehr an Edge 1030 Plus?
Hallo,
als ich mein Edge 1030 Plus neu hatte, wurden keine Tracks usw. vom Basecamp auf Gerät übertragen.
Nach einem Update hat das dann funktioniert.
Seit ein paar Tagen bekomme ich aber schon beim Anschließen des Gerätes die Fehlermeldung, dass BaseCamp keine Daten ans Edge übertragen werden könnte- was auch der Fall ist.
Gemäß der Fehlermeldung soll ich ein Update installiert werden, ich habe aber schon die aktuellste Version???
Hat jemand Rat???
  • I have exactly the same problem with the 1030 but only recently. The error messages have been desplayed for a long time and Basecamp has not been able to transfer tracks or routes with the designated software buttons. I used to work around by exporting the tracks/routes directly into the "New Files" folder on the SD card or the Edge. Never had a problem with this. Only starting from June 3rd on my Edge1030 is no more able to transform the gpx files into .course.fit files. (from neither of both sources)
    I did a reset of the Edge but did not get an improvement.
    I have changed the SD card with no result. I have deleted all GPX files from the appropriate folder in case there's a limitation there with no results. The "New Files" folder is empty in both cases after starting up the device again but the new courses are not there.
    Interestingly, I can push a file directly into the user data folder of the card or edge and it's beeing displayed on the computer but of course not in the device.
    My firmware is 11.10
    Anybody has some advice?
  • There sems to be a limitation with the number of couse.fit files. I had 85 on the SD card and 15 on the device. I did a back up and deleted all course files. No the import works again (according to my work araound)
    I foundf the clou to do this in this post.
    forums.garmin.com/.../972620
