GPX / TCX Import doesn't work anymore - FW 9.00/9.02beta
Hi,
I've tried to import today 3 different GPX Tracks (from alltrails.com) in a lot of different ways.
=> copy them 1:1 via USB connection into the Garmin/New Files folder
=> convert one with gpsvisualizer.com to gpx and copy 1:1 into the Garmin/New FIles folder
=> import one to gpsies.com and export a GPX track again, afterwards copy 1:1 into the Garmin/New FIles folder
=> send all three files via Basecamp to the Edge 1030 (first of all import the GPX files into Basecamp)
But nothing of this very different ways are working anymore with firmware 9.00/9.02 beta for me.
What are the differences since the firmwares before or the known limitations (i.e. only 50 tracks) for storing tracks.
Are there any known modifications for the procedure of importing GPX tracks to follow them on the map?
Any help to fix this is very appreciated!
Thanks!
Michael
    0 Former Member over 5 years ago in reply to Former Member
    Yeah, that was the way I did already a few minutes ago. So no files anymore.
    Basecamp is also strang, sending the imported fit files back to the device (selecting the SD-Cards) resulted in still no GPS tracks on the E1030.
    So I'm doing no the hard way either copy the needed .fit files back and forget basecamp or reimport GPX files (copying to the Newfiles folder) by using the Original ones if available or convert the .fit to .gpx with gpsbabel. ;-)
