Edge 1030 software version 3.80
Change History
Changes made from version 3.70 to 3.80:
Improved temperature reporting.
Improved Bluetooth connectivity.
Fixed issue where closing GCM on iOS would break the connection with the Edge.
Fixed issue where BLE would remain on after disabling the phone setting on the Edge.
Improved Edge remote connectivity.
Fixed issues with Device Transfers.
Fixed issues with editing power zone values.
Enabled turn-by-turn navigation support for courses imported from GPX tracks.
Increased automatic screen brightness in low-light conditions.
Fixed issue preventing anti-aliased CIQ fonts.
Fixed issue where segments were not blocked while using CIQ apps.
Fixed issue where the widget indicator bar would not fade away while viewing a CIQ widget.
Fixed units sync with the Varia Vision.
Fixed issue with elapsed time when the timer is paused.
Fixed small odometer data field to allow more digits to display.
Fixed VAM data fields.
Improved sharp bend warnings.
Improved device stability.
