Edge 1030 Firmware Version 4.00 und beta 4.01
Edge 1030 software version 4.01 Beta
Changes made from version 4.00 to 4.01:
Fixed issue preventing the device from connecting to Garmin BaseCamp.
Changes made from version 3.90 to 4.00:
Added enhanced support for Varia RTL510 radar tail light.
Updated touchscreen firmware to 85.11 to fix responsiveness in low temperatures.
Added CIQ 2.4.4 support.
Improved device stability.
Added the ability to discard the current ride at any time. This requires several interactions to avoid accidental discards.
Fixed text conversion issues.
Fixed issues with the Varia Vision data screen setup causing the Edge and Varia vision to be out of sync.
Fixed issue preventing a BLE sensor from being added if it was the first sensor.
Fixed issue where the ANT generic channel used by CIQ data fields would not reconnect when the device resumes from sleep.
Fixed issue where searching for a long address would not provide a proper result.
Fixed issue where battery save mode would turn on GPS in the Indoor activity profile.
Fixed issue preventing some iPhones from staying connected during the pairing process.
Fixed issue preventing activity uploads after saving a ride.
Fixed issue where the ascent remaining and ascent to next course point data field values did not match the total ascent for the course.
Fixed various issues with sharp bend warnings.
Fixed issue where FTP would be reset after recording an activity with a CIQ app.
Fixed issue preventing battery save mode if the timer is auto-paused.
Fixed issue where calories would be incorrectly calculated for BLE power meters.
Fixed navigation audio prompts
Leider laut Changelog noch immer kein fix für die Remote!?! Hat schon jemand diese Versionen getestet?
