What is required for indoor cycling to record speed & distances when using a Forerunner 935??
Hi I'm new to recording my training stats so what I would like to do is when I go to my gym is record my cycle distance & speed on an indoor bike. If this is possible then what additional equipment would I  need to record these stats. Any information received will be very much appreciated so TIA.
    0 Former Member over 4 years ago
    Hi, it depends on the trainer type you are going to use with your bike. Smart trainers, which control power/resistance can broadcast speed, power etc. via Bluetooth and you can see these data on the watch as soon as you pair the watch with the trainer. If you have a more simple trainer you would need at least Garmin speed sensor, which is attached to the wheel as well as cadence sensor.
