Treiber Display 2.50
Dieser Treiber wurde bei mir Heute installiert. Leider habe ich keinerlei weiteren Infos hierzu.
Zudem soll wohl auch die SW 6.0 ausgerollt werden:
Fenix 5X Production Software 6.0 Now Available!
Yesterday, 02:52 PM
Software version 6.00 for the fenix 5X is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
09/21: Current Phased Rollout: 20% of users
Change Log:
Added support for Rep Counting during Strength and Cardio workouts which can be created on Garmin Connect Web and Garmin Connect Mobile. To enable Rep Counting, ensure that Settings > Activities & Apps > Strength > Rep Counting is enabled. Start the timer to automatically count reps during sets. Press the lap key to rest between sets. You can edit the number of reps and weight for your last set during a rest period. Press the lap key to advance to the next set.
Added support for All-Day Stress. To view the Stress widget, hold the Up key from any widget and select Add Widget > Stress. You can view your current stress measurement on the widget page. Press the enter key to view a graph of your stress over the last four hours. Press Down to access the Four-Fold Breath relaxation timer.
Added support for setting up Wi-Fi Networks on device. After syncing with Garmin Express or Garmin Connect Mobile at least once, go to Settings > Wi-FI > Add Network to search for Wi-Fi networks. Select a network. If the network is secure, enter its password to join it.
Added support for manual calibration of the Barometer. (Settings > Sensors & Accessories > Barometer > Calibrate)
Added support for Hourly Alerts. (Settings > System > Time > Alerts > Hourly)
Improved device key handling while using Connect IQ apps.
Improved the course navigation icons for better visibility and contrast.
Fixed an issue causing Varia UT800 Smart Headlights to periodically disconnect or power off during a ride.
Fixed an issue causing the Running Dynamics Pod to disconnect when using Connect IQ Apps.
Fixed a potential issue preventing a course from being joined when not joining it at the start.
Fixed a potential issue causing Personal Records to be reported inaccurately.
Fixed an issue where the device would not transition to the climb screen while using Auto Climb in certain situations.
Fixed an issue where the sunrise and sunset alarms were not working as expected.
Fixed an issue where the elevation plot for a single activity in a multisport activity would display the elevation history of the entire activity.
Added support for configuring the track color of saved activities. (Settings > Map > Track Color)
Fixed an issue where certain artifacts were being drawn on the map page while panning or zooming.
Fixed an issue where the device might crash when editing settings for a multisport activity during a transition.
Fixed an issue where the map would not refresh course data if it was edited during active navigation.
Fixed a potential issue where the watch may appear frozen on the watchface, when exiting out early from an active course route calculation.
Fixed a potential issue preventing some Training Status data from being uploaded to Garmin Connect.
Note: There are language files and display update that is available to all users right away.
    Das sieht aktuell nicht danach aus ... dafür ist die Fehlermeldung für das Update der Fahrradkarte wieder da .... :o :o :o (die können programmieren) ... :cool:
    Die Beta 5.84 läuft bei allerdings stabil - da verstellt sich nichts - außer dass GearMin sich einmal zurückgesetzt hat ... aber das liegt wohl eher am Watchface.
    Oh ja wenn die was können dann das :D :cool: Wird mal Zeit für ein Maintain Garmin ;)
    Bis auf einige Garmin typische Fehler läuft auch bei mir 5.84 ohne Probleme. Wenn sich allerdings die Sprache ständig verändert ist dies ein Indiz das etwas vergessen wurde bzw. auf ein Bereich mit fehlender DE Sprachdatei zugegriffen wird. Fehlende Textpassagen sind mir in Version 5.84 soweit nicht aufgefallen.
    Kommando zurück ... soeben erscheint die 6.0 auf der Uhr ... :)
    Nur das Kartenupdate geht trotzdem nicht .... :o :o :o
  • Schon komisch. Weder bei meiner Fenix 5 noch bei meiner Freundin die 5s hat was von Display stehen bei Info.
  • Wenn sich die Sprache auf Englisch verstellt sollte man mal die Einstellung in Garmin Connect (Mobile) prüfen. Bei mir ist das die Ursache.
    Leider ist es bei Garmin anscheinend so, dass die Einstellungen in GC Mobile die der Uhr überschreiben. D.h. ist dort Englisch eingestellt kann man das auf der Uhr hundert Mal ändern und die Uhr stellt nach jedem Sync trotzdem wieder zurück. Das Selbe gilt übrigens auch für die Alarme! Wenn die in GC eingeschaltet sind, dann gehen sie am Morgen los, auch wenn auf der Uhr deaktiviert (und zu meinem Leidewesen teilweise auch andersrum, da ging mal ein Alarm nicht los, den ich auf der Uhr gesetzt hatte).
    Das war aber zumindest in der 5.4 (und wohl auch schon früher) so.
    Grüße
