FW 3.99 Beta
Im Moment funktioniert der Download leider noch nicht.
Changes made from version 3.98 to 3.99:
◦Improved touchable accuracy of red pin removal
◦Fixed issues with Direct Routing
◦Fixed routing behavior after changing Activity type during an active route
◦Fixed issue causing Routing Avoidance selections not to be saved
◦Fixed issues when disconnecting from mass storage
◦Fixed issues with map set selections across Profiles
◦Fixed issue causing 'Use' button to not display on the map
◦Fixed display of waypoint icons in Recent Finds list
◦Fixed issue with Favorites menu caused by changing Profiles and restarting unit
◦Fixed issue with main menu dashboard caused by changing Profiles via shortcut on main menu
