Fenix 3 Fw Update 6.24 beta (09.12.15)
Changes made from version 6.19 to 6.24:
Added support for Row App. New features include 500m pace, stroke rate, stroke count, distance per stroke, upgrades to virtual partner, stroke rate alerts, and 'every beat' metronome option.
Added support for Row Indoor App. New features include stroke rate, stroke count, stroke rate alerts, and 'every beat' metronome option.
Added support for Standup Paddleboarding (SUP) App. New features include stroke rate, stroke count, distance per stroke, upgrades to virtual partner, stroke rate alerts, and 'every beat' metronome option.
Added support for Golf App. New features include download of courses through Garmin Connect Mobile, distance to front/middle/back of green, layup distances, measure shot, scorecard, and odometer/round timer.
Added support for Project Waypoint App (Settings > Apps > Project Wpt.).
Added support for a new ABC widget which combines Altimeter, Barometer and Compass data. Note: previous altimeter/barometer plots and compass view will be accessible through this new widget (Settings > Widgets > ABC).
Added support for a new HR gauge data screen (Settings > Apps > Activity > Data Screens > HR Gauge).
Added new Hands and Background analog watch face options (requires Display firmware version 2.92).
Added support for audio lap alerts in Garmin Connect Mobile. (GCM > Garmin Devices > Fenix 3 > Audio Alerts > Lap Alerts)
Fixed potential issues with battery discharge beyond the typical rate.
Fixed a potential issue with Off-course alerts not working for certain use cases.
http://www8.garmin.com/support/download_details.jsp?id=9504
Notes:
* If upgrading from public version 5.10 or lower, we strongly recommend that you 'Restore Defaults' after the upgrade. If not, you may see some oddities within App lists, etc...
* Garmin Connect is not yet ready for Fenix 3 Paddle Sports. Therefore, you should not expect to see appropriate data when uploaded to your GC Account.
* If you add the new ABC Widget, the individual widgets can be accessed still by pressing 'Start' when on the ABC Widget itself. You can then use the up and down arrows to scroll through each individual page.
    Endlich Golf! Nun ist sie komplett.....die Uhr. Jetzt fehlt nur noch der Sommer zum Testen.
    Heute massive Syncprobleme (via Bluetooth mit dem Smartphone). Noch jemand?
    Jepp. Hatte Heute morgen auch das Vergnügen und dann aufgegeben. Da der Akku aber eh schon wieder leer ist (Sonntag letzte Ladung) darf Sie ans Kabel und somit gleich mal Express laufen lassen.
    Kommt einem doch entgegen das der Akku mal knapp 2-3 Tage hält, so muss der Synch via Smartphone ja auch nicht zwingen laufen da eh fleissig geladen wird.
    Fehler gefunden: Nämlich zwei defekte .fit Dateien. Beide wurden mit der neuen Ruder-App erstellt.
    So nach einigen Tagen kann ich mich auch äußern, zur Beta Version. Batterieverbrauch liegt ohne Aktivität bei 14% -16% pro Tag, BT aus. Desweiteren hatte ich das Widget Batterie Gauge deaktiviert und wenn ich dann durch die Widgets blättere stürzt die Uhr ab und löscht die Aktivitäten :confused:. Das gleiche passiert wenn ich die App "SUP" deaktivieren möchte. Also Batterie Gauge wieder aktiviert, "SUP" drauf gelassen und sie läuft wieder. Diese Version hat bei mir mehr Schaden angerichtet wie Verbesserungen, schade. Also warten und hoffen auf das nächste Update.
    SUP Phänomen sowie Verbrauch passt wie die Faust aufs Auge zu 100% mit meiner überein. Krass!
    SUP Phänomen
    Konnte die SUP-App bei mir problemlos direkt an der Uhr deaktivieren. Dafür… Apps via Connect App neu anzuordnen funktioniert nur mit 'nem Uhrabsturz. :eek:
    ich glaub ich geh auf 4.9 zurück, ich verliere langsam das Vertrauen zum guten Stück. Nur noch Ärger, Batterie wird leer gesaugt, häufige Abstürze und zur Krönung ist sie heute einfach im Training hängen geblieben, nach 5 Minuten hat sie dann vibriert und mich gefragt ob ich die Aktivität fortsetzen möchte, dabei war ich im Gedanken schon beim Hard-Reset. Hoffentlich kommt bald ein Update vom Update was alles wieder fixt.
  • Meine Fenix lief gut.
    Leider habe ich heute bei einem Traillauf keine Höhenmeter angezeigt bekommen. Im Ziel ist mir aufgefallen, dass der Höhenmesser durchgehend eine Höhe angezeigt hat, der Barometer zeigt seit ca. 40h den gleichen Druck.
    Soft Reset hatte keine Auswirkung. Erst Autokalibration an und Aktivität starten bis GPS Fix hat die Höhenangabe reanimiert. Jetzt funktioniert es wieder.
    Heute morgen wäre es wichtig gewesen.
