Beta 6.52
und das Beta Programm geht weiter...
[h=2] Fenix 3 - 6.52 Beta Release[/h]Here we are back at it with a new beta software. Working towards the 6.50 public build was quite the undertaking. No need to stop now, right?
If you are so inclined, please update to 6.52 beta and take with you this weekend on whichever adventure you choose. We'd love to hear if any bugs exist at [EMAIL="[email protected]"][email protected][/EMAIL].
You can grab the beta update here:https://www8.garmin.com/support/down...ls.jsp?id=9505
or here: https://www8.garmin.com/support/down...ls.jsp?id=9504
6.52 Change Log Notes:
• Added support for CIQ 1.2.2.
• Added Intensity Minutes widget (Settings > Widgets). Note: requires a connection to a Heart Rate Strap to accrue Vigorous minutes.
• Restored support for the (optional) manual entry of Sleep mode (Settings > Activity Tracking).
• Fixed a potential issue with display of day/month on the watch face. (Requires display update 3.01)
• Fixed a potential issue with the vibration setting getting affected after a software update.
• Fixed a potential issue with the Floors climbed goal being reported as 0.
• Fixed a potential issue with the backlight coming on for Smart Notifications, after placing the watch in ‘Do Not Disturb’ mode.
• Fixed a potential issue where the unit would crash when using paddle sport activities within a multisport profile.
• Fixed an issue where steps were not showing up on the last sport widget for a walking activity.
• Made other minor UX bug fixes and improvements.
Help us keep moving forward with the momentum. Have a safe and adventurous weekend!
  • Ich habe noch die 6.52 drauf und mir ist heute morgen was komisches aufgefallen.
    Ich habe gestern Abend den Wecker gestellt der mich heute morgen wunderbar hat verschlafen lassen.
    Den Schlafmodus habe ich über Go to Sleep gestern Abend eingeschaltet und heute morgen wieder durch betätigen einer Taste, ausgeschaltet.
    Was mir dann aufgefallen ist, dass die Beleuchtung bei Gestik nicht mehr funktionierte. Ich dachte dann ich mach einen Neustart und dabei ist mir aufgefallen, das " Do Not Destrub" auf "an" stand, das hatte ich aber definitiv nicht aktiviert.
    Ich habe die Vermutung, dass der Wecker das aktiviert hat, kann das sein?
    Mit der 6.55 sollte das ja wieder funktionieren, oder?
    Das selbe hatte ich ich hier schon beschrieben, ein Update hilft.:cool:
  • Das selbe hatte ich ich hier schon beschrieben, ein Update hilft.:cool:
    ja, aber Du hast nicht geschrieben, dass durch aktivieren des Weckers auch die "Do Not Distrub" Funktion eingeschaltet wird, was meine Vermutung ist.
    Das könnte dann auch bei anderen das Verhalten erklären, dass sich die Fenix 3 gar nicht mehr meldete.
    Falls es jemand noch mal checken will.
    Ich werde heute Abend die 6.55 drauf machen, da scheint es ja behoben.
    Die Funktion wurde bei mir auch nicht aktiviert, sondern lediglich der Wecker bis aufs blinken deaktiviert. Habe das dann an Garmin gemeldet. Und siehe da, bei der nächsten Beta wurde es korrigiert. :D
  • Ich habe jetzt mit der 6.52 nochmal den Wecker getestet.
    Ergebnis: Er hat überhaupt nicht gepipt und vibriert, ergo war der Wecker in 6.52 defekt, lag wahrscheinlich gar nicht am Schlafmodus.
    Jetzt mache ich gerade die 6.55 drauf.
