finale Firmware 3 erschienen
Changes made from version 2.20 to 3.00:
● Added support for CIQ SDK 1.2.6.
● Added support for Achievements. (Summary of personal records available after an activity is saved, and while still on the saved activity summary page.)
● Added support to turn off activity monitoring Goal Alerts. (Settings > Activity Monitoring > Goal Alert)
● Added support for post activity download of Heart Rate data from HRM-Tri and HRM-Swim sensors. (History > Activity > Download Heart Rate)
● Added support to calibrate altimeter at extreme altitudes.
● Added floors climbed history to the steps widget.
● Added the heading bug to the elevation plot page.
● Added support for saving a waypoint from the Dual Grid page.
● Added support for displaying status of GPS EPO data to the About page. (Settings > System > About > Scroll to the EPO Status Page, Note: downloaded EPO data will not always be stored on the device file system)
● Added support for viewing more than 100 Saved Locations on the device.
● Added support for Walk App (Settings > Apps > Walk).
● Added support for Swimrun App (Settings > Apps > Swimrun).
● Added additional backlight settings: a 4 second timeout and a 5% backlight level.
● Improved distance scrolling on the Project Waypoint page.
● Improved Bluetooth to phone connection reliability. (Requires BLE/ANT FW 3.50)
● Improved auto zoom during waypoint navigation.
● Improved the readability of golf course names on the golf course list page.
● Improved reliability and accuracy of Heart Rate data. (Requires WHR FW 2.30 (10.02.21))
● Improved accuracy of floors climbed data
● Fixed a potential issue where the device could crash when saving a swim activity with HRM Tri data.
● Fixed a potential issue where Intensity Minutes were not being calculated correctly for devices paired with a Heart Rate sensor.
● Fixed an issue where the Auto Scroll setting was not available for paddle sports activity profiles.
● Fixed a potential issue with Timer alarms not working as expected if Do Not Disturb was enabled.
    Meldet er ... Du kannst aber sicherheitshalber überschreiben ... ;-)
    Danke, habe ich jetzt gemacht. Den Punkt "erneut installieren" hatte ich übersehen.
    Bilde ich mir das nur ein, oder ist der Stromverbrauch im Uhrmodus (ohne Aktivity Tracker) gestiegen?
    Seit heute geht WLAN und der Connect IQ Shop bzw die App installation wieder mit meiner Uhr.
    Garmin Express wurde auch aktualisiert, jetzt läuft alles wieder wie gehabt.
    Der Akkuverbrauch meiner Fenix3 HR kommt mir soweit normal vor.
  • ... also ich kapier es immer noch nicht. Da steht auf der Garmin.at Website:
    fēnix® 3 HR
    Unit Software
    • * Beta Software: fenix 3 HR, Ver. 3.00, Beta as of Apr 28, 2016, Download
    *Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
    Garmin Connect liefert auf keine Info, dass irgendwelche Updates anstehen.
    Woher kommt die Information, dass dies die offizielle Finale Version sein sollte ???
    Gibt es hier einen Garmin-Moderator, der dies bestätigt?
    Aus meiner Sicht lediglich wieder eine neue Beta Version, vielleicht auch ein Final Candidate, aber mit dieser Info
    auf keinen Fall ein Final. Die letzte offizielle Version war auch eine 2.20 - also irgend eine Versionszahl.
    lgr
  • Auf der DE-Seite ist auch noch die Beta verlinkt.
    Meine Vermutung ist, dass "Public Releases" nicht per manueller Installation sondern generell per Garmin Express oder OTA angeboten werden. Man kann ja vom "gemeinen" Anwender ja nicht verlangen, dass dieser Dateien hin- und herkopiert ;).
    Hallo,
    so ist es - zumindest beim Sync über Garmin Express wird die jeweils aktuelle Version bei der Versionsprüfung automatisch installiert, wenn sie noch nicht auf dem Device aufgespielt wurde.
    Ansonsten bislang noch keine schlechten Erfahrungen mit der Version 3.00 - Aktivitäten weisen keine 'Ausrutscher' auf, der Batterieverbrauch scheint sich auch nicht wesentlich verändert zu haben, die GPS-Genauigkeit ist wie zuvor. Also, bei mir alles im grünen Bereich.
    Besten Gruß
    Ich hatte heute bei einem Wettkampf (Lichtenstein Trail HM) einen bösen Aussetzer in FW 3.0. Die Uhr ist auf eine HF-Warnung minutenlang "hängen" geblieben und war nur durch einen Softreset ("Light" sehr lange drücken) wieder vom HF-Warnungsbildschirm weg zu bekommen. Meinem Rennen fehlen so auch 2km (aber nachdem ich den HF-Sensor sowieso testen wollte, hatte ich noch eine zweite Uhr an, also kein Problem).
    Danach waren alle iQ-Apps durch "Timer" ersetzt, der Navigationstrack (Karte, ich hatte eine Routennavi an) war noch da, aber es gab keinen Bildschirm mehr mit dem Höhenprofil (was vorher sehr gut funktioniert hat).
    Kennt das jemand von euch?
    Das Verhalten kenne ich noch zu gut von meiner Fenix 3, aber ich dachte das wäre überstanden, da hatte ich auch immer nur Reboots, nie einen solchen minutenlangen "Hänger".
    Ach ja, die HF-Messung ist manchmal recht genau, zeigt aber sehr häufig ziemlichen Schrott an...
    Grüße
    Ralph
