Too much white screen and not enough data
Why is it, Garmin, that you need to reserve half of my screen to white space so that I can not see that data for my splits without scrolling to the right? And when I do scroll to the right, I can no longer see what split I am looking at and I also lose sight of all the other data I just went past. It is worse in this new and improved version than it was in the original. Two solutions: (1) Use all that unused blank white space to the right of the data and the problem is solved. (2) Allow me to eliminate the useless columns of data so I can at least squeeze the data I most want to see onto a single screen. In the meantime, does anyone know how I revert to the old Garmin Connect?
Go to https://connect.garmin.com/dashboard that will switch you to Garmin Connect "Classic." Or, click on the profile icon, then select "Switch to classic temporarily."
Or you can zoom out the web browser window - Hold down Ctrl then tap the minus key.
I agree with you on the columns. Half of them I don't care about. That should be user configurable.
Thank you, Seilogramp. I learned something new tonight. Still feels like a workaround for questionable design, but it is a solution, so I need to step off my soap box. I appreciate the assist.
