Hi there community I have looked through some old posts and have tried the various things I have found but to no avail, all help will be most gratefully received. So here goes I'll try to describe accurately my problem.
My 910xt attempted to "transfer data" via the USB ant stick, after a while the Garmin ant agent pop up window on my desktop said that the transfer had failed. At this point the screen on the device still displayed "transferring data" and the back light was also stuck on.
After consulting the wisdom of the forum I attempted a soft reset, the screen went blank and since then I have seen very little signs of life.
So currently if I push the power button there is no response, if I hold the power button for around 10 seconds the screen seems to change colour slightly but there is no data on the screen, no beep or no vibration.
I have tried to connect the charger and again there is no response, I have also borrowed my sister's charger with the same results. At the time of the transfer my battery was at around 75% I think and I have previously had no battery related issues.
I hope that somebody can shed some light on this, thanks Gareth.
