Speed vs. pace
On the Dashboard, why is average speed shown for some activities, but pace is shown for others? Is there a way to change this, or to get both to display?
  • This is set by Activity type - Running activities are always pace and cycling always speed - not sure what the settings are for all the others - but you can't display both and the only way to change would be to set a different activity type i.e. if you are running and cycling and you want both to display speed you would need to set your running activities to one of the types that uses speed (e.g. Fitness Equipment). Far from ideal but would get you one measure across your activity types if that's what you need and would still let you spit out the activities in filter mode just using an incorrect description
    Thanks! I suspected something along those lines, but it's helpful to have it confirmed.
    Why then if you go to the activities page with only running activities shown are the columns shown as speed and not pace?
  • In connect when I go to the activities page it shows mins/mile for my running activities and minutes per 100 Metres for swims and miles per hour for cycles - are you talking connect or connect mobile?
