Customer support refuses to fix sync problem between Garmin and my fitness pal
Below is a copy of an email I just sent to Garmin customer support which is passing the buck on a syncing problem between Garmin connect and my fitness pal. Because this is happening to three different Vivofit's I hope others will utilize the social media to apply pressure to fix the problem not blame the other guy
Matt: I am very frustrated. My Garmin connect has refused to sync with my fitness pal since December 18, 2014. I have written Garmin customer support on at least four occasions. This problem not only involves my Vivofit/Garmin connect but also my wife's and as of December 26, my son's new Vivofit given to him as a Christmas present. The only advice customer support has been giving me is to disconnect and then reconnect which I have done on multiple occasions, and is doing nothing.
Now your advice is to contact my fitness pal, which was advice given to me five days ago and which I did to no avail. I suggest to you that it should not be my problem to sort out which system (yours or my fitness pal) is the source of the problem. You should be contacting my fitness pal, sorting out the problem or problems, and resolving them between the two systems.
Your Vivofit success depends on the interaction of these two systems. I suggest that if you have at least three Vivofit's malfunctioning in one family you have a systemic problem that the Vivofit team should be all over. Please advise me of the results of your contacting my fitness pal.
Joe Buchanan:mad:
  • I'm also having the same problem for weeks. If I go into the GC calories and manually sync for each day it works. My calories show up on GC and my activities show up on MFP. It appears the automatic sync is not working. I've tried disconnecting from each side and connecting from the GC side. I still have to manually sync.
    Don't bother asking Garmin support. They are pretty much useless with anything except helping you to do a factory reset of your device or offering to sell you a refurbished unit because yours is "obviously defective after the firmware upgrades". They are never made aware of issues with the GC site even after calls to the GC support which takes 20 minutes on hold. Apparently Garmin employees don't use their own gear or else these problems probably would have been fixed already.
  • I too am experiencing the same problem. No matter what I try the 2 programs will not talk to each other. I hope they come up with something soon.
    Seems you should go to myfitnesspal.desk.com, as it seems MFP has had problems syncing with a number of other sites that they are working to fix. When GC to MFP became unstable, so did MFP to withings, fitbit, bodymedia, and others....
    0 Former Member over 10 years ago
    Yes, it is very disappointing that this doesn't work properly any more, because it was one of the most useful features of the Vivofit. I, like many people, use Myfitnesspal religiously and unless Garmin is going to push out a competing product, it might be in there best interest to fix this. There are plenty of products out there that could easily replace my Vivo and I won't hesitate to take MY money elsewhere.
  • Yes, it is very disappointing that this doesn't work properly any more, because it was one of the most useful features of the Vivofit. I, like many people, use Myfitnesspal religiously and unless Garmin is going to push out a competing product, it might be in there best interest to fix this. There are plenty of products out there that could easily replace my Vivo and I won't hesitate to take MY money elsewhere.
    See my post just before yours. MFP broke syncing with a number of devices about the same time. Why do you assume it's the Garmin end? Looks like its not!
    I replied before seeing your post, hence the identical post times...regardless, you are correct, I shouldn't have assumed that it was Garmin's issue.
  • I replied before seeing your post, hence the identical post times...regardless, you are correct, I shouldn't have assumed that it was Garmin's issue.
    There are now about 10 threads right now that start with blaming Garmin for not fixing the sync issues, including one where a poster blasted Garmin for telling them it was a MFP problem and to contact MFP.
    Syncing between two sites is like a dance, and it always "takes two to tango". People need to understand that if there is a problem, it could be either end, and need to check the user forums on both ends.
    I had this same problem but tried again today to disconnect and reconnect from the computer, not from the app, and it worked! it didn't work for me yesterday so not sure if something changed or if i just got lucky, but maybe worth another try.
    I received a new vivofit for Chrismas and cannot get GC to read the calories from MFP. Please help resolve this issue.
