The "Current VO2max" number on Garmin Connect used to change after almost every workout - up or down just a bit. When I look at the VO2max Trend graph, it shows the last month or more with the VO2max in the high 50's. The value currently reported on my device (fenix2) is 56. The "Current VO2max" number has not changed for more then a month and shows as 52.
Shouldn't the Current VO2max number be the same as the value at the last point in the trendline, which should be the VO2max value calculated from your last workout and shown on your device?
This issue is the same in both Modern and Classic views.
Has anyone else seen this? A website bug, or a user error?
Thanks.
