Issue with Connections widget when no connection has "Activities"
If you have the Connections widget set to All or Steps and at least one connection has steps, you get this bar below to switch between the tabs:
If you try to switch it to Activities and no connection has activities, the bar is removed and you can't get back to the All or Step tab:
The only way to get back to the All or Steps tab is to remove the widget and re-add it since it defaults to All.
