Ultra-trail values are not within permissible limits. WT...?
Hello Everyone!
I recently completed ultra-trail "la diagonale des fous" and recorded it with my garmin fenix on ultratrac mode. Unfortunately, values are not real because of the interval between each point recorded. Ok, but when I try to modify, GC says : your ... value is not within permissible limits (time, distance, d+).
Garmin don't think runners can do a 172km/10000d+ trail or don't think it's fenix can record 59h?
I was proud of my performance and can't show it on my dashboard... :confused:
Is there a solution?
    How far off are the values it saved in Ultra mode? Can we see the unedited activity?
    Values are : 159km, 10000m elevation gain, 59h05'43''. All are already too big for garmin connect. So far, I just could I don't know how change distance to its real value, 172km, but elevation gain is now 10m!! You can see the activity here : http://connect.garmin.com/activity/620721507
    Thank you!
    First of all, CONGRATULATIONS!
    Now, when I look at your activity it is perfect. 107 miles = 172 KM. It shows elevation GAIN at 10 M yes, because that is literally all you gained over the total of the event. You started by the sea, ascended through the mountains and then DESCENDED to the sea. You did not end your journey on the top of the mountain. I see your max elevation at 2500 M. This is a VERY high climb.
    I believe you may have climbed a total of 10000 M over the entire course but that was not your max elevation.
    Your activity looks perfect to me. Post it up proudly.
    Thank you for congratulations :)
    But about the activity, no, this is not perfect. Usually, GC shows the SUM of elevation gains, not the difference between gain and loss. And I can't modify duration neither. Because duration max is 40hours!!! Elevation gain is max 9000, the only value I can change is the distance...
    And thanks for trying to help...
