Cadence chart not shown when using an indoor rowing machine
Hi,
I have a Concept 2 model D with PM4 that can connect to the Garmin ANT+ devices.
The PM4 transmits the start/stop/power/cadence/speed data to the Garmin watch which records it.
The problem is that the Garmin connect site doesn't display the cadence chart. I know there were issues with the cadence chart when running with a foot pod, but these seemed to be fixed at least for me.
Here is a rowing session in which the cadence is not shown:
http://connect.garmin.com/activity/481079596
Later edit: I just noticed that the cadence data is not saved in the tcx file ... I was not expecting this. I will have to contact Concept 2.
Please support.
    I have the same problem (and I found several other threads similar to this). The cadence data IS in my activity -- you can see it in the exported TCX, and Training Center has no problem displaying sensible values. I think there's a bug in Garmin Connect.
    I'm using an FR70 with a Concept2 PM4. Here's a sample activity:
    http://connect.garmin.com/activity/485445261
    Note that the average and max cadence in the summary are exactly two times what they should be.
    Same over here!
    In fact, I have recorded both with FR70 and FR610. Same story. With Model D and PM5.
    In reality when I import the activity into SportTracks 3.1, I do get the sroke rate under candence field
    But in Garmin Connect, it does not even show up.
    By the way, I am not seeing this stroke rate multiplied by 2 to match the running dynamics thing, I am just not seeing anything at all in GC
    anyone found a solution to this?
    thx
    6co
