Ant Stick doesn't recognize my Garmin 910XT
I've had the Garmin 910XT for a year now and every once in a while the Ant Stick will not connect with the watch. It is utterly frustrating since the two normally connect as soon as I plug both into my USB ports. I've restarted & shut-down my computer about a million times, but still, nothing. Any suggestions? I've also checked the settings on my watch and pairing is enabled. I haven't changed any settings so this issue should not be occurring. HELP!
    My device is a GARMIN 610, the problem was with the ANT Stick, USB ports and my device not connecting to my computer.
    I had the same problem with garmin express, I tried a lot of things, and what worked for me was the following:
    Open control panel, go to the uninstall programs and uninstall everything related to garmin,(I had, garmin express, training center and garmin usb ports) restart you computer, download just the ANT AGENT software, run it and install it, let the ant agent recognize your device. Go to the task manager, end process of the ant agent, and now, install garmin express and everything should be fine. It worked for me pretty well, hope the some for you.
