Synchronising problems with Forerunner 310xt
Having a couple of synchronizing issues with my Forerunner 310xt as follows:
Using Ant+
It said transferring data in the display, but after a minute or 2 it stopped and the pc said it occured a problem during synchronising.
Then I installed Garmin Express and more or less the same happened. I can neither transfer from the device or to the device. However, when using the upload button on the Garminconnect page, I managed to upload one activity. But I have several activities still not transferred and undetected.
The Garmin also turns itself off after a few attempts to transfer.
  • It sounds like you may have a corrupt activity file on your 310. You may be able to determine which file is the problem by looking at them in your history and then deleting the problem file. If you don't mind losing your activities, you could just delete all of them.
    Travis
    Thank you, found a file that would not be deleted, so ended up with deleting all activities, and that worked :-)
