Explore doesn't work
I have a problem with http://connect.garmin.com/explore - it doesn't work. The left side is not displayed
  • I have the same problem - and the goals are only shown in the dashboard, but not under the "plan"-button :confused:
    Same problem here. Have not been able to see og plan goals the last days.
  • It might be useful if you guys tried to figure out what is common between your configurations that might be causing this. What browser, what browser version, what OS, what language (the original post looks like Polish)... Obviously there is a problem here, but without additional information, nobody is going to be able to help you.
    FYI, I'm using Internet Explorer 11 on Windows 8 as well as Chrome 32.0.1700.107m on Windows XP SP3. I'm not having any trouble.
    Travis
  • My configurations:
    Windows XP, Version 2, Service Pack 3. Browser: Google Chrome 32.0.1700.107 m does not work, and IE 8 does not work either...
    Mac OS 10.6., Safari and firefox don´t work...
    I tried to switch from German to English - no change, the same problem persists.
    Could it be an "European" problem? ;-) I´m living in Vienna, Austria
    Or outdatet software???
  • and the problem started after a homepage-maintenance of garmin connect on 02-05-2014...
    It's Polish. Windows 7 SP1. It doesn't work on Firefox, IE, Chrome. About week ago everything was ok.
    Same issue here, worked fine untill very recently, now nothing in results
    Using chrome 32.0.1700.107 m
    IE 11
    Both on Windows 8
    Language set at English, measurements in Metric, living in Belgium
    Interesting, it works normally on my Work Laptop running Win 7, same Chrome versions as above...
    Could it be a plug-in issue ?
    Voila, issue found, manually updated Java and now it works !
    I had Java updated so I reinstalled it but still it doesn't work.
