Edit workout created by Garmin Connect on Edge 800
I usually create cycling workouts on Garmin Connect, then send them to the device. The problem is Garmin Connect doesn't provide all different Power readings that are available on Edge 800 so I have to edit each step individually after transferred the workouts to Edge. For instance, on Garmin Connect I'd select Custom Power from 220W - 250W, then after transferred the workout to my Edge I'd have to edit the step, and change it to Power 30s Average from 220W - 250W.
I thought it would be so much simpler if Garmin Connect would provide all measurements available on the target device so that workouts can be built for various workout goals.
Is there an easier way to do this?
KTran
