Course Transfer issue on Edge 810 from Garmin Connect website
Hi,
After having enjoy the usage of the forrunner 610, I purchased recently an EDGE 810. I would like to use it to discover new road so I'm creating a course from an activity and then modify the routes on the garmin connect web site (so for example passing from 44,xx km to 78 km so no confusion could be made as I almost double the distance). When I save the course in Garmin connect, it has the new map and the new distance (if I close the internet browser and open it again, the course is correctly saved) but when I transfer it to my device, I get the old route, the old distance and the old statistics. Can I know what is wrong?
I try with two internet browser: Chrome and IE. My system is a Windows 7 64 bits.
Thanks.
  • In fact, if I change the average speed of the course, then the course is correctly transfered to the device.
    So I think that there is a kind of bug in Garmin connect. If you only change the map information (by changing only the routes), the course looks correct in Garmin connect but it's a course corresponding to the source activity which is transfered to the device (independently of the fact that you use the Gamin connect web portal or the iOS application), as soon as you change the average speed, then the course transfered to the device is the one corresponding to the new intinerary. At least, I have a workaround for the moment but it would be nice if the bug can be solved.
