Feature suggestions (after some months of using Connect)
I'm very pleased with the Connection but some features needed are missing.
Some suggestions about possible new Connect features:
- Dashboard : ability to turn off records and goals, so that they do not appear on the dashboard
- Analyze --> Activities: Ability to edit for example activity type for multiple activities at the same time.
- Analyze --> Reports : Speed is only measured in km/h. Pace (min/km + avg pace and max pace) needed here!
- Plan --> Calendar : It would be nice if there was a possibility to view the calendar one week at a time with activies positioned according to their starting time. Meaning there would be times from 6 am to 12 pm running in the rows and days would be in the columns. This would give nice information about training of the week. Of course distance totals of the days and week would be a nice bonus here.
- Plan --> Goals : It would be nice to be able to set goals without target dates, for examle: just 10000km running from start date no target date included.
- Profile page: Last 12 months graph would be better if the measured value could be selected. For example, you could show distance run monthly for last 12 moths. Of course even better if time span (12 months) and zoom level (moths, weeks) could be changed.
- AND FINALLY ONE POSSIBLE BUG (or maybe not?): Your real name is visible on the Explore->People search even if the searching user is not your connection and your profile is just visible for yourself and connections.
    Also after using my forerunner 405 and Connect for nearly a year I'd like to suggest the following:
    1. Ability to remove spikes from data (e.g. sometime you'll have a crazy figure for speed on the pace which then scales the graph to a meaningless scale e.g. 1m/mile to 12 m/mile.
    2. Ability to chose scale of graph your self (will help with problem) above.
    3. Abilty to edit recorded runs e.g. to remove data from the end if you forget to stop your watch!
    4. Ability to learn runs when you import them. i.e. If you run the same route regularily you shoudln't need to name it each time you import it. Connect should recognise it and name it automatically. This would also enable you to easily see you PB's per route.
    I look forward to developer comments on the above.
    Thanks,
    Ian
    I would Like to Second that it would wonderful to have a graphical view of activities. A place where I could see a graph of distance, avg. pace, time, etc. over a selected period of time. This would make it very easy for visual people, like me, to see the progress over time of my workouts.
    Thank you very much for your time,
    Andrew
    I support this very much. It appears for me at every track (due to loss of signal in underground crossings etc.).
