I'm thinking that a solder joint has come adrift somewhere as the unit is fine otherwise, but difficult to read.
As I'm located out in Cambodia, there is zero chance that I can send the unit in for repair, as the cost would be more than the $127 I paid for this new!
And then there's the fact that a repaired unit being sent to Cambodia, will be quite likely to go 'missing' in the post (VERY common).
Is there a service manual or circuit diagram anywhere that I can use to pinpoint the problem?
We have a very good tech dept here in air traffic control, which has repaired SMD discreet devices for me in the past, so I think that this unit will be no problem.
**UPDATE**
We checked over the unit, and all the connectors were disconnected and reseated, a visual check of all ribbon cables made and reseated.
PCB main board visually check, no apparent components damaged.
The screen is showing a 'misty' display, apart from the last 10 lines at the bottom (see photos).
Any ideas will be gratefully received.
Email me or PM: xu7adq (AT) gmail (DOT) com
The unit works fine apart from the display which is difficult to see in daylight.
Thanks
PP
