Hi all,
I have Garmin Edge 305 and have been using it for some time now. I have noticed recently that when I use the lap function in my Edge 305 during a ride, the data for the last lap is repeated once. On the map of the ride, there is a line from the end of that lap back to the beginning, and in the speed/altitude/heart rate graphs there is a loop back when I view these versus distance or time. If i change the view to "Moving time" then the data can be seen to repeat more clearly. I have searched the forums and knowledge-base but was not able to find this issue reported before. Have you all seen this? is it an issue with Garmin Connect or with the device? Is the only solution "dont use the lap function?" (not a solution)? Are "Laps" only intended to be contiguous loops so the software is trying to make that happen?
Here is a link to a ride from yesterday that had this issue http://connect.garmin.com/activity/113001633
