Forerunner doesn't connect due to "code 43" error on USB port
hi,
when i try to connect my forerunner to my laptop, i get the message that it isn't recognised due to a code 43 error.
the only way i've been able to fix this is to uninstall all USB ports and reboot. but that needs to be done everytime, very annoying!!!! :mad:
has anyine else had this problem, and if so, how did you fix it?
Thanks!
    0 Former Member over 11 years ago
    error codigo 43
    yo tengo el mismo problema, error código 43, estoy desesperado no se que hacer, si alguien puede darme una solucion
    (Bing translates as 'I have the same problem, error code 43, I'm desperate not be do, if someone can give me a solution')
    Code 43
    Same problem here! Garmin can you give us the solution?
    hi,
    Thanks!
  • A code 43 error can be generated due to problems with the device. You may find a master reset of the device will clear the error.
