Zumo 660 odometer problem
I just got a replacement Zumo 660. The unit is fine except the Odometer will not reset. any body have any ideas. I really do not want to send this GPS back again!!!
    After much time and frustration with Garmin support they tell me that this is how the unit functions. Sounds like BS to me but I will give it a try. They say if It changes usage to a car or off road them it has to be hard reset. It sounds like a sofetware problem that has not been addressed
    fuel tracking does not work
    based on OD not being able to reset the fuel tracking does not work. i have turned this feature off as i wanted to track 200 miles then alert me to pull over and get gas. the OD must control this and it always tells me i am out of gas 50 miles into the trip
    Same problem
    I have the same problem, yours at least gets 50 miles, mine triggers as soon as I turn the unit on, I've got frustrated and turned it off that function.
    Any luck on your end?
    Thanks.
