add support for MANUAL body fat entry...
suggest adding support for MANUAL body fat entry whilst I save up for a BC-1000...!
Can manually record body weight, but not body fat, easy fix I am sure! :)
thanks
    0 Former Member over 14 years ago
    As you can read elsewhere, this is a long overdue isse - and nothing will probably happen anytime soon. At least I've lost faith in Garmin Connect and have moved to runningfreeonline.
    In their health section you can input weight, body fat and resting heart rate. You can even delete wrong inputs :D
    Guess I'll check back here once in a while - just to see if they ever wake up or let it all go down. What a waste, though....
    this program start to sound more and more inresting:
    http://www.runningfreeonline.com
  • Only way I have found to enter all values manually (cause I've another Tanita scale) is to build & upload FIT file myself using the Java tool provided with the FIT SDK.
    Working great :D
    It's a bit boring to do, maybe I will make a tool do this automatically when I'll have more time.
