So, I've been having some small issues with my Garmin GPSmap 60CSx
Specifically, we have a small test map uploaded under the maps menu (symbol "i" with a circle around it). The map shows up and is selectable, futhermore, there is a square on the screen where the map should be showing up (when the map is selected, the gray sqaure is there with blue crosshatching around it. When the map is deselected there is no gray square). However, there is no map image, just the tan background. How do I get the image to show up?
Other notes-
- the map is showing up in the correct area according to longitue and lattitude
- Cycling through detail settings elicited no change
- Cycling through land cover distance elicits no change
Thanks,
I look forward to hearing back from you
UCR Research Staff
