when I switch on climb or surface preview, I cannot see exact position on track, same if it is switched off
Hi there, Can you please provide the model of browser as well as the software version that this activity is being viewed in? As well as can you provide the type of activity that is being viewed?
hi there,
it is Safari 27.2 and Chrome 157.0.8103.39 on macOS 27.2 Golden Gate, and also Chrome on Win 11 (updated to latest versions, but I have no access to check numbers now)
not sure what you mean by software version being viewed in, it is Garmin Connect web version
it is not activity preview, it is Course preview, no matter what type of Course (road, gravel, mtb)
EDIT: today I have discovered that there is also missing part of the course on map, and that was probably because of incorrect import
also I'm attaching how does Connect look like in Safari on iPad Air 5 with iOS 27.2, absolutely unusable
When a specific data field is selected while previewing a saved course, the exact position dot will not appear on the map. If you would this changed, please use the below form to get this forwarded to the appropriate team.
