System Bug: Issues with "Quick Edit" on Activities
Reproduction Steps
  • Login to http://connect.garmin.com
  • Select Activities from the top menu
  • Ensure you have enough activities for paging to be activated
  • Select "2" from the bottom of the grid
  • Select "Quick Edit
Expected Results:
The quick edit will enable you to modify the items in the grid that showed up for paging index 2
Actual Results:
The quick edit flipped to paging index 1 instead changing the items you will be editing.
