Garmin Smart Scale not connecting nor syncing
I can set the wifi using the Garmin Connect App on my Pixel 8 Android phone. But then the scale flashes first all three bits of the wifi icon, then has two bottom steady one, but the upper bar of the wifi icon keeps flashing. In my network, I can see the scale is connected to the right network and the IP address assigned. So if I then run a Wireshark scan for all traffic from that IP address on the access point it connects to, the below is the only IP traffic coming from the scale. It seems it's only querying clock.garmin.com, and after a while time.google.com!? Is this failing ultimately the entire connection with Garmin Connect, and therefore not syncing any data?
No. Time Source Destination Protocol Length Info
7036 89.898462 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
7071 90.450519 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
7107 91.577465 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
7186 93.257590 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
7243 95.510295 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
7321 98.335511 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
7546 101.335686 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
7761 105.248507 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
8162 109.784156 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
8791 114.854758 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
9226 120.515968 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
9514 126.732363 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
9848 133.352219 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
10468 140.616738 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
10725 148.451420 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xe9fa A clock.garmin.com
10983 156.910681 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
11011 157.430065 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
11065 157.994765 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
11103 159.116585 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
11145 160.789541 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
11268 163.012046 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
11312 165.859970 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
11480 169.248831 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
11926 173.190243 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
12279 177.549541 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
12419 182.659783 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
12581 188.326321 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
12785 194.479643 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
14135 201.022637 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
14333 208.355884 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
14639 216.212292 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xa035 A clock.garmin.com
15061 224.674920 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
15070 225.191577 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
15077 225.749093 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
15153 226.890767 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
15201 228.568289 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
15387 230.826899 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
15908 233.658735 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
15982 237.068369 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
16260 240.959839 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
16415 245.494702 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
16583 250.594405 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
16816 256.186617 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
17298 262.434621 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
17564 269.141413 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
17789 276.471730 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
18028 284.396589 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xc7fa A clock.garmin.com
18905 292.857788 192.168.20.163 8.8.8.8 DNS 79 Standard query 0xde5f A time.google.com
163788 2709.608454 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
163798 2710.160740 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
163856 2711.276488 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
163931 2712.964442 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
164038 2715.191483 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
164297 2717.943510 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
164479 2721.271612 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
164714 2725.142854 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
165009 2729.566262 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
166098 2734.535350 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
167229 2740.116329 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
167600 2746.210644 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
168032 2752.871264 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
168641 2760.205610 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
168864 2768.121056 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xf84a A clock.garmin.com
169371 2776.589993 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
169395 2777.109979 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
169406 2777.674754 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
169418 2778.801513 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
169472 2780.489228 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
169544 2782.744007 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
169627 2785.579323 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
169738 2788.939629 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
169936 2792.767508 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
170128 2797.210904 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
170418 2802.129053 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
170652 2807.780357 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
170901 2813.984260 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
171842 2820.795351 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
172200 2828.177827 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
172719 2835.970491 192.168.20.163 8.8.8.8 DNS 80 Standard query 0xd1a1 A clock.garmin.com
173283 2844.202732 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
173353 2844.680054 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
173391 2845.206918 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
173593 2846.306019 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
173957 2847.946088 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
174080 2850.123596 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
174210 2852.897682 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
174445 2856.256596 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
174527 2860.186991 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
174724 2864.683988 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
175052 2869.742702 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
178927 2875.341946 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
182032 2881.492967 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
187181 2888.107444 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
187533 2895.398397 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
187824 2903.288642 192.168.20.163 8.8.8.8 DNS 80 Standard query 0x71a5 A clock.garmin.com
188080 2911.710221 192.168.20.163 8.8.8.8 DNS 79 Standard query 0xba61 A time.google.com
