Unable to upload from Edge705 to Garmin Connect
Hi all,
I'm fairly new to Garmin Connect and I was trying to upload a file from my edge 705 to Garmin Connect. Garmin Connect does not seem to see the file. I then tried to open in SportTracks and got an error message. Can anyone help?
The 'Trackpoint' start tag on line 2 does not match the end tag of 'T'. Line 2, position 451170.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.ThrowTagMismatch(NodeData startTag)
at System.Xml.XmlTextReaderImpl.ParseEndElement()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
at System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at ZoneFiveSoftware.SportTracks.IO.LogbookIO.Open(String filename, IJobMonitor monitor, JobResults& results)
    It would appear the file is corrupt. If you wouldn't mind attaching it to your reply or sending it to me in a PM I will take a look at the file.
    I am assuming it is just the one file, correct?
