3s power graph
The 3sec power display on my device is a great help during an activity. Is there a way to display a graph of this in Garmin Connect? The current unsmoothed graph is too spikey to be useful.
  • I don't think this is possible either in the Connect app or website, without the use of a 3rd party Connect IQ data field. This data field would have to independently calculate 3s power and record it to the activity file, so it appears as a graph in the activity details in Connect.
    I happen to have a CIQ data field which can do this. Since it's pretty flexible - it's basically "excel for your garmin" - it does require some setup.
    Notes:
    - this will work with cycling power on all devices
    - this should work with built-in running power on currently supported devices (released in the past few years) which have up-to-date firmware
    - this may not work with built-in running power on older devices
    - the very latest devices - Forerunner 570 / 970 and Venu X1 - are not yet supported
    I assume you are *not* referring to Stryd power, as you seem to be referring to the built-in 3s power data field. My guess is that you are talking about cycling power, but let me know if i'm wrong.
    Setup:
    1) Install AppBuilder 5 from the CIQ store: https://apps.garmin.com/apps/fd690281-9c22-4fee-a81e-3b7f39aa67c5
    2) Configure the following settings for AppBuilder 5, using the Connect IQ mobile app:
    - Label:
    POWER (3s)
    [or whatever you want]
    - Display Format: Auto
    - Record to FIT file: Yes
    - Formula:
    timeavg(power, 3)
    3) Add AppBuilder 5 to the activity of your choice
    Sorry for all the steps - if I knew of a simpler CIQ data field that does what you want out of the box and supports modern devices, I would def recommend it over mine
