Forum Problems (Nov 2024)
In the last days the forum seems to be have some problems, so perhaps we could try to collect some data from people experiencing them, and also to post some available workarounds.
So far, I know about the following problems, and have experienced all of them too. The suggested workarounds sometimes work, but it is not a rule, so you may need testing more alternatives:
  1. Access to the forum blocked, with an error message from CloudFlare
    1. Deleting cookies for garmin.com and cloudflare.com
    2. Using a different browser (i.e. Firefox)
    3. Using Incognito Mode
  2. Impossible to submit a reply to a post. Usually it happens when the reply contains one or more of the following items:
    1. Embedded image or file
      Workaround:
      1. Hover over the pasted image in the message body, and in the menu that appears, select "Convert to Link"
      2. Post a link to an external storage instead (may not work either - see the next item "Hyperlink")
      3. Post without the image, then edit, and try adding the image then
      4. Try replying to a different comment - i.e. the OP instead of the last post, or vice versa
      5. Remove the image from the post
    2. Hyperlink
      Workaround:
      1. Click the link, press Ctrl-K, and remove the "Text to Display"/ Simple link without the alternative text usually passes all right
      2. Remove the hyperlink
      3. Post the link as plain text (remove the leading https:// and paste it in plain-text mode with Ctrl+***+V)
      4. Try adding the link later after editing your original post
    3. Quote
      Workaround
      1. Remove the quote and just copy and paste it instead of using the built-in quoting feature (you can use Format » Formats » Blocks » Blockquote for making it look alike)
      2. Use Tools Source Code and remove the hyperlink from the code
      3. Try adding the quote later after editing your original post
    4. Special characters - in some cases some simple characters like the parenthesis, double or simple quotes, or even a question mark may prevent you from submitting the reply
      Workaround:
      1. Unfortunately you will have to experiment which of the characters causes the trouble, and remove it.
      2. Sometimes copying the entire text and pasting it back as simple text (Ctrl+Shift+V) helps
      3. Often, you can use another similar character instead. There are many Unicode characters that look similarly, and can replace the original. For example ⁇,  Grey question, Question, ¿ for the question mark, ´ for the apostrophe, [ ] instead of parenthesis, «» for double quotes, but there are many other alternatives as well.
  • Before submitting a post, you can test it by selecting Tools > Preview. If the preview window is blank, then your post will not work.
  • pdurys said:
    I am not sure if problem is resolved, but I can post comments with links from Android phone but not pictures
    If you enter the link as a plain-text url, and the forum doesn't linkify it before you post, then there should be no problem.
    The problem is when a url becomes linkified (so it's blue and clickable) *before* you post. This can happen a couple of ways:
    - you type a url and the forum decides to automatically linkify it for you (after you press enter, for example)
    - you use CTRL-K, CMD-K, or Insert > Link to manually add a link (e.g. if you want the link text to be different than the url)
    - you edit an existing post that has a link (such as yours)
    The forum problems aren't resolved for me.
  • It does seem that it's possible to post true links from mobile (although the process of doing so is a bit harder, since you need to copy an already-formatted link from somewhere else).
    EDIT: nope
    A link with the same text as url (like https://www.google.com) seems to work (step in the right direction), but not a link with different link text than url, like "link to this comment".
  • Link was blue before posting and yes I just copy paste URL from Chrome on Mobile.
  • Yeah it seems it works on mobile (iOS for me) as long as the link text is the same as the url.
    But if I create a link in my notes app with text that differs from url like "link to comment" (and the url points to a comment in this thread), it's still rejected by the forum.
  • Still canNOt post at least some of these characters: single quote, double quote, parentheses, question mark, exclamation mark
  • I also noticed that strikethrough formatting causes posts to be rejected.
  • I have another problem now. I cannot turn off notifications to this thread. Even in email link to mute site does nothing I am not subscribed to it but still getting emails.
    Here are also no thread options.
  • Yeah, others have mentioned a similar problem. This thread is missing the thread options sidebar for me, too.
    Does it work if you scroll to the original post and select More > Turn Reply Notifications off?
    As I already mentioned in the OP, as well as a few times later in this thread, I can post all of this when using the forum in browser's Incognito Mode: ( ' ) " ? !
    Also available and working (for me) in the Incognito Mode
