Hi, I have experienced an issue after a weight training session yesterday whereby the data did not sync to GC. I have the file from the watch, please can someone kindly repair or advise what I can do to fix the problem.
Similar issue on my epix, running beta software v16.13. I ended up deleting all activity history from the watch under \GARMIN\ACTIVITY, then doing a hard reset. If it happens again, I will do a reset to factory defaults. For the workout that wouldn't sync, I just manually created it in Garmin Connect Web. Of course, it's missing a lot of the metrics, but at least I have a record of it.
Thank you for your feedback. I am using the same software version as you. I did a HR recovery at the end of this particular session on the watch and may have jumped out of the screen as it was saving. Hopefully just a little blip… I’ll also reset the watch and delete old logs if it persists.
I did similar to you for now as a work around, however used an older session from last month and date changed to keep the metrics, then created a manual entry for the older one as those metrics will be irrelevant now.
