Hello can somebody please help me with fit file which is most probably corrupted due to power loss? Fit file cannot be manually uploaded neither to garmin connect nor to strava.
[solved]
Thank You
Petr
This will work - [SOLVED]
Fixed using Fit File Repair Tool
As you mentioned, battery flatlined.
This can also be fixed using FIT File Tools, using the section remover without any adjustments.
