Save trimmed activity as...
Hi, I would appreciate your help. I use Garmin Fenix 6 to record our paddling training. It may consist from several activities (interval training, 200 m sprint, 1 km run, etc.). All recorded as one activity divided into laps. Then in Garmin Connect I would like to split the whole activity into pieces and save separatelly. Later I may compare e.g. all 1 km runs. I dont know how to do that. I know how to trim, but I am missing something like SAVE trimmed activity AS... Thanks a lot
  • The watch. Adding Hot Keys to fēnix 6 Series
    On my Forerunner 945 I use long press on start to "change sport". Note that you don't have to actually switch sport. If you select the same sport it will create a multisport activity with two activities of the same type.
  • OK, I will try. I may add my own multisport, but number of activities (all are kayak) may differ from training to training. It seems to set number of activities first.
  • You don't have to create an activity in advance. Just start an activity just as you do now. When you want to create a multisport activity you just use the hot key and change sport. That will automatically create a multisport activity. Continue to change sport every time you want to add another activity.
  • You are so kind. I tried to create Multisport DRAGONBOAT with 3 kayaking sports and repeating (It could be just one activity and repeating I think. It works good in my home chair :-D. Now I try to do your last recommendation. Each activity in multisport cannot be renamed, right? So better to describe steps in Notes.
    Edit: Multisport with repeating will need just one press, changing sport are two (hotkey to the next sport and confirmation of sport).
    Thank you so much!
  • Edit: Multisport with repeating will need just one press, changing sport are two (hotkey to the next sport and confirmation of sport).
    True. If you don't need to mark laps then a prepared multisport type will work better.
    You can't rename each activity in a multisport. They will just be numbered with the "activity type 1", "activity type 2" and so on. Example Running 1, Running 2...
