I have not received the trick or treat badge so I can not share it to get share the scare badge
Whatever, they should fix it, people see the Trick or Trick badge for ages and prepare themselves to get it. So the best would be if they fix it by awarding it to whoever made an activity in 2022 + make…
This year there is only one Halloween badge: Halloween 2022
The others are moved back to 2021. Garmin made a mistake when they moved back the dates and forgot to set an end date wich makes them visible…
I wrote this reply in another thread about the same issue:
The others are moved back to 2021. Garmin made a mistake when they moved back the…
You have to do it from the phone Garmin Connect app, not the website.
Click your profile picture, then click "badges", then click on the Halloween badge.
In the badge's window, in the upper right there is a share symbol.
Click it and share it (I don't think it matters where you share it - I share it to a text to my wife)
You may have to hit the sync thingy and sync the data so it goes from your phone to the
Garmin database before you can see it.
