I have not received the trick or treat badge so I can not share it to get share the scare badge
Whatever, they should fix it, people see the Trick or Trick badge for ages and prepare themselves to get it. So the best would be if they fix it by awarding it to whoever made an activity in 2022 + make…
This year there is only one Halloween badge: Halloween 2022
The others are moved back to 2021. Garmin made a mistake when they moved back the dates and forgot to set an end date wich makes them visible…
I wrote this reply in another thread about the same issue:
The others are moved back to 2021. Garmin made a mistake when they moved back the…
I've try also, and it only work if share by email!
Any one got 2 badge of the Halloween? My friend did 2 activities, and I did the same, but she got 2 points and 2 times the badge of Halloween.
Any one got the same? know how it works?
Did you change your country settings in between. I don’t think youll’ll get multiple identical badges in the same day, but you can get the different regions badges if you change your country.
Hello, thank for your input. No I didn't change the setting. And my friend also didn't change the settings.
I tried txt and email and they didn't work. Tried imgur and that worked.
Didn't work either, thanks anyway!
I managed to get 6 badges of the same Halloween badge by doing a multisport activity. Did your friend do a multisport activity?
It feels like an incorrect behaviour of the system. You should only get one each year.
I guess you are trying to share the Activity, not the Badge. You have to tap on the Share symbol on the Badge detail screen to get the Share the Scare badge.
