Troubleshooting guide for (some) data missing after syncing
When you find that after syncing, part of the data is still missing in your Garmin Connect Account (for example the heart rate, steps, Intensity Minutes, or Activities), then there are basically the following possibilities. The most common and the most likely reason in most cases is the #4.
  1. First of all, as also in case of most other problems with your device, the first thing to try, is a soft reset (typically - holding the Light button for some 20s, until the device shuts down), or powering down and powering up the device. It often fixes weird behavior, especially after firmware updates.
  2. Your Privacy Settings do not allow sending data to the Garmin Account (verify the option Storage & Processing), or the device is not set as the Preferred Activity Tracker (check out the Device Settings on the Garmin Connect Mobile app » Activity Tracking » Preferred Activity Tracker)
  3. The BT synchronization on the phone app does not work (the white circle around the watch symbol never closes) - in that case follow the tips in the Sync / Connection Troubleshooting Guide. Alternatively, you can sync the data with the GC account over the USB cable and Garmin Express on a computer, or manually by importing files from the device folder //GARMIN/ACTIVTY/ to the Import Data page of GC Web (in case of errors during the import, see the hint #4). On Android devices you can (and you should) also review the Device Sync Audit (in GCM Menu » Settings), and browse though the last audit reports looking for errors and warnings.
  4. When the synchronization works (the white sync circle closes and turns green), but not all the data is appearing in your account, then it very probably means that there is problems with the association of your device to the GC account. Again, try restarting the watch (if you did not just do it), and shutting down the GC Mobile app (iOS: swipe it up in the iOS App Switcher; Android: Android Settings » Apps » Connect » Force to Stop), and then restarting it. If it does not help, remove the device from Garmin Connect, and then add it back again. If it does not help do all these steps:
    1. Remove the watch from the Garmin Connect Mobile app
    2. Sign out of the GCM app!
    3. Remove the watch from the list of Bluetooth devices on your phone (Android or iOS system settings » Bluetooth !
    4. Remove the watch from the Garmin Express on the computer
    5. Sign out of GE!
    6. Remove the watch from the Garmin Connect Web
    7. Sign out of the web account!
    8. Sign in back to your original Garmin Connect account on the app, and add the watch again. Repeat with Garmin Express.
    Please note that this operation will not bring back the lost data, but it prevents that it continues to happen!
  5.  When it does not help, perform the Master Reset of the watch/device - it will have similar effect, but you will need to redo some configuration and customization of the device.
  6. The storage (or a FIT file storing the Activity details or HR data and the steps data) is damaged or full. Try backing up and deleting old files from the folder //GARMIN/Activity and //GARMIN/Monitor. Look up the last unsynced activities from the folder //GARMIN/Activity, and try importing them manually on the Import Data page of GC Web. If you get errors when trying to import them, try fixing the broken files by passing them through the Section Remover of FIT File Tools (without removing anything), and then importing again the repaired file(s).
  7. If you own a second-hand device, or a device from not a well known online reseller, there is a chance it is a stolen, or a counterfeit device. Garmin continuously removes any such devices with known S/N from their database, disabling so their syncing to your Garmin Connect account. If you suspect it could be your case, contact the Product Support, ask them to verify the serial number of your device, and if not found in their database, or when being on the blacklist, contact the seller and request a refund. See an example of such case in the thread Help with data not updating after sync.
  • Well, you can simply sync over the USB cable to a PC with Garmin Express - if any unsynced files are still on the watch, then they would be transferred. If it does not help, then there are very likely no files, but you can look up for example the folder //GARMIN/Monitor.
    Also, as  correctly noted, you should double-check that the date (!!!) and time are correct both on the watch and the phone (as well as on the PC)! It could be that the data was synced, but if the time or date were different on the watch than on the phone, then it was stored with a wrong timestamp. In such case there is little you could do to fix the lost data. By adjusting the time & date, you can only prevent happening it again.
