Hi,
is there any problem with sso.garmin.com? - I am not able to upload fit files from multiple devices via Connect API.
Thanks
I'm also experiencing issues affecting my site https://garminbadges.com (it is still working but not all functions)
I'm using a number of different services to collect data for the site and now several of them returns error 402. It seems to be all services that returns JSON data. I can still access them from inside Garmin Connect Web if I inspect the page, but that is not a very good solution for my users.
These are the ones I'm using:
[https://connect.garmin.com/modern/proxy/badge-service/badge/detail/v2/1] - to get data for each badge
[https://connect.garmin.com/modern/proxy/badge-service/badge/earned] - for my users to submit their badges
[https://connect.garmin.com/modern/proxy/badge-service/badge/attributes] - to get attributes for the badges
I also use these but mostly in this forum to help people:
[https://connect.garmin.com/modern/proxy/badgechallenge-service/badgeChallenge/F5555622CAC247549468E95C91708474]
[https://connect.garmin.com/modern/proxy/activity-service/activity/6261178238]
So are you able to login to https://sso.garmin.com/sso/login without no problems?
Not directly, but still can upload fit files through Garmin Connect without problems. Are you using a 3rd party app for the upload or do you have problems using Garmin Connect or another app from Garmin?
I believe Garmin added another level of security and disabled the direct access to the data, which was to be expected sooner or later, especially after the hacker attack last year. The security audit they did afterwards, certainly recommended them these measures.
