If you've enabled LiveTrack with "Extend Session Visibility," and it's not past 24 hours ago, you might be able to recover the GPS track using a LiveTrack converter, such as LiveTrack…
What was the distance supposed to be? I see about 2.9 miles or 4.7 km.
Some fit files can be fixed by FIT File Tools, using the section remover without any adjustments. The result can then be uploaded to Garmin Connect Web using the Import Data page. I tested your file, so this…
Did you see Post #1204852 marked as answer?
I had the same issue with my Garmin 1040. I have attached some of the files I found, maybe the more relevant (due to file size and date/time) is M7DN4100.FIT. Thanks.
File is downloadable here: https://www.dropbox.com/scl/fo/griihf9c8u6h52u662usz/ANj0EFi258StsOF4CTclG3c?rlkey=0lsqzd0gydtu9syjk46reoeov&st=kmyy27k2&dl=0
Yes, it was a triathlon. The swim was 3850m, 1:27:xx (when I looked at the watch coming up from the water), T1 some 400m walk, 16:xx (together with the swim1:43:57 from the race system), bike 206 km 7:52:46, T2 7:13, and the run until the watch died about 30km, I think. There was a run checkpoint at about 28km where the running time was 4:22 and the watch still had battery.
Hello. This is my link: https://easyupload.io/oxzkll
I used Active Undelete for recovering my deleted activity and I tried to repair it with fitfile repair tool, but the program said after few minutes just ,,Overflow,,. Thanks for help
