une fois la séance de natation effectuée, comment modifier la distance enregistrée sur Garmin Connect? par ex en cas de séances mixte avec longueur en jambes uniquement.
montre VIVOACTIVE 4 S
merci !
merci !
Faux, la distance reste Grisée ! Impossible de la modifier ! C’est quand même incroyable vu l'imprécision bien connue du comptage des longueurs ! Cela devrait meme pouvoir se faire directement sur connect en fin de séance. GARMIN reste sourd au propositions d’amélioration de ses users.
Please post a screenshot of what exactly is greyed out.
You can submit your request here, if you have not done this already - https://www.garmin.com/en-US/forms/ideas/. No guarantees it will be implemented, but if enough similar requests are made, they might take notice.
While you wait, you can edit swimming activities here - www.swimmingwatchtools.com
Additionally, if you change the activity type to a different GPS activity, such as running, then you might be able to use the "trim" feature in Garmin Connect Web. Then change it back after the distance is edited.
The distance is grey and cannot be changed
You need to change the number of pools, not the distance. The distance will be recalculated automatically.
Open the activity, tap Edit, scroll down, tap More Data, modify the number of pools, save.
