temperature / heat acclimation wrong
Hi,
the heat acclimation and the temperature, which is dislayed in the corner of the map are less to low. I can train hours at 25°C, and my acclimation drops, because in the map there is 17°C.
This happens with two devices, Edge 1030 & Fenix 6X Pro.
Does anybody know, if I'm doing something wrong?
Thanks
  • The temperature on the map shows the temperature from the closest weather station, so if it shows the wrong temperature, you may need to contact the meteorologists, and ask them to fix their weather station Smiley You'll find the meteo source ID, if you click the temperature on the map - and you can then look up in Google, the exact location of that source.
  • Thank you for this info with the source.
    I found, that the problem is, because there is only one request at the starting time of an activity.
    When you do a 10 hours- bike- tour, starting at 9am, there is only the request at 9am.
    At this starting time, there will be 15° for example, but afterwarts over hours about 25 or more. So the accuracy of the heat acclimation is not really good.
