Hi,
I do mtb/indoor cycling (1030) and rowing using Fenix 6s. My F6 is quite new and I expected that all training from 1030 and F6 are eventually synced through Connect App to both device, so I have one Training Status (Physio TrueUp).
But as I completed my first indoor cycling today I found out, that data in both devices are different, which confuses me. In F6, the activity recorded by 1030 is present and correct, however the Physio data are off.
VO2 for a starter is 46 in 1030 and 49 in F6. Training Load in 1030 is 287, in F6 286 (OK, quite close) but Recovery Time in 1030 is 33 hours (as it should be since I have done the cycling today) and 0 in F6 - this data should be same AFAIK?
What is also confusing me that in Connect App, in "Training Status", I can select 1030 or F6 in Graphs. All graphs are same but 7 days training load graph is showing different data for each device, I expected to have same data..? As an result, 1030 is advising "balanced" and F6 is advising "Too low low-aerobic load" - I again expected to have same data and ONE training status, as advertised in Physio TrueUp feature page.
So is this a bug or should I check something to make it work? Or I am not understanding this function correctly?
Thank you for your comments / help.
Tomas
