Same problem here, frustrating! My power meter had an off the charts reading back in March which set my FTP at 383 Watts and 5.07W/kg. I deleted the recorded ride with the spike but the Garmin app did nog…
Same here! +1
i am not 100% sure, if this helps, but you can delete wrong records in the new power curve menue:
I corrected the FTP setting on the Fenix as well, so my next ride will be correct again.
Same problem here, frustrating! My power meter had an off the charts reading back in March which set my FTP at 383 Watts and 5.07W/kg. I deleted the recorded ride with the spike but the Garmin app did nog remove the reading. There is no way to manually correct the data. My actual FTP should be between 280-300 watts at the te moment but the Garmin Iphone app is sticking to 383 watts. Totally worthless...
When will this bug be fixed?
Unfortunatelly it doesn't help, I am also stuck with a super high value even if I've deleted the wrong record and have also completely eliminated the power data from that ride. With that high value connect is completely useless :(
Come on Garmin, fix this please and provide a method to reset / remove erroneous values from historical FTP graphs.
As much as I wish, I do not have a "most recent" FTP of 5.6 W/Kg!
Can´t you reset your FTP value on the Garmin device and then sync?
