Workout Calendar Not Syncing Once Again - Forerunner 735XT
I'm not sure if there was an update that broke this, but all in the sudden my workout calendar from Garmin Connect isn't syncing with my Forerunner 735. When it was working a couple of weeks ago it would ask me to select my device and click "Done" (Like in my first image). Then it would sync. Now it just says "Your workouts will be sent to your Garmin device next time you sync" instead of asking me to select the device (Like in my second image). And of course it doesn't sync.
Anyone have any suggestions or is this something that was broken in an update?
This feature is a big time saver when you get on the pool deck or start your run and expect today's workout to be there. ciq.forums.garmin.com/.../1359006.png ciq.forums.garmin.com/.../1359007.png
  • I´m having similar problems: 735XT with Galaxy S7 on Android 8
    working: upload of activities from the watch to garmin connect, pulse, steps etc.
    sending single trainings from garmin connect to the watch also works
    I´m also getting smart notifications, so the bluetooth connection seems to work.
    not working synchronization: scheduled activities in the calendar, all trainings at once, pulse zones
    workaround: calendar sync works via cable and garmin express, trainings work, pulse zones do not work - must be adjusted on the watch
    I´m also having the problems for about 2-3 weeks now.
    I also tried to sync with my nexus 10 with android 7 - doesn´t work as well.
    Resetting the watch and deleting the app also wasn´t helpful...
  • What does Device Sync Audit report?
  • I have added two workouts for this week, sent them to the watch and synchronized manually.
    The workouts didn´t arrive, but I can see no error Message - see below.
    Tried it via cable and garmin express - synced correct...
    ---Sync Info---
    ******************** SYNC RESULT ********************
    Upload Status=SUCCESSFUL (No item to process)
    Download Status=SUCCESSFUL (No item to process)
    Time Sync Status=SUCCESSFUL
    Overall Sync Status=SUCCESSFUL
    Origin=5037_1
    UPLOAD:
    LISTED (No item to process) { listed=678ms }
    #Auto Upload=true
    #Types=[32, 35, 4] |
    DOWNLOAD:
    BROWSED (No item to process; No downloadable items found for the supplied bit mask (256)) { browsed=202ms }
    #BitMask=256
    Same issue, for my Fenix 5x, cant see anything on my calendar
  • I have the same issue. Workout set to the calendar wont sync with my Forerunner 235. The message content has changed. It used to be a window showing that the plan from date 1 up to date 2 will be sent, while now it is a simple message that "Your workouts will be sent to your Garmin device next time you sync"
    this is quite annoying.
    last sync was late may early june. after that nothing
  • At least the synchronization with Garmin Express works for me again. Unfortunately still not in the app.
    Windows 10 and Microsoft Edge works. I didn't try Firefox, because it mostly didn't work with Firefox.
  • Same issue for me - can't get the calendar to sync at all from the app, but if I send it from the website, and then sync hard-wired from Garmin Express, it will work. Really frustrating as I update my calendar frequently, and having to hard-wire sync is painful, when it should work through bluetooth. I've tweeted Garmin about it a couple of times, but my requests for help have been ignored. Would be really helpful to get an update from Garmin on whether they're aware of the issue, and what's happening to get it resolved.
    FR235, Samsung S8
  • I have the same issue on forerunner 935 latest ios app and watch os. Wont sync from app or desktop app anymore. What I have found that has worked twice for me now is to restart your watch.
    Hi , I am trying to understand why is my workout from training calendar are not synching to my device (735XT latest software installed). I can see that all the workout have been synced but are not showing in the calendar except from one workout. That workout is showing in my device training calendar every occurrence but nothing from the other workouts.
    I have tried to sync from the web interface, the Connect software from my Android phone, resetting my FR 735Xt and then sync back.
    Even tried to manually go to each workout, assign them manually on the device and then sync the device, no success. If anyone could help me on that one it would be awesome.
    Thank you!
    Mathieu
    For me it doesn't work either (Connect Mobile on Android with Fenix 3) although I was just able to somehow trigger it via web interface, after clicking Send Workouts to Device I was prompted to pick the device (like in Connect Mobile app some time ago). In the end it fails in browser (due to the link format) but then the connect app sends properly calendar to device. check screenshots
    ciq.forums.garmin.com/.../1367886.png
