Swimming Personal Records Not Showing Up
I have been doing a lot of lap swimming lately tracking using my 920XT. When I got the personal records page there are no records listed for any of the distances, it doesn't seem to have translated any of my swims to the records. The only personal record filled in is for longest swim and it was an open water swim.
Does Garmin Connect not support personal records for pool/lap swimming despite having a tab for it? Has anyone experienced this and found a fix.
    0 Former Member over 5 years ago
    I think I know what you need to do if the distance for longest swim doesn't show up:
    You log in in Garmin Connect, you select "reports" on the left column, you select the swim report where you had swam the longest distance, on the upper right you have a "wheel" for the options and there you can click on "set as PR". At this point you can select the right personal record option. Then you can see int he left column again under "personal records" your new record.
    I hope I could help you guys out.
    Have a good swim ;)
  • Two years is a long time to get back Joy.  But the problem still exists.
    I have a Garmin Vivoactive 3
